Champion Bracket no A/c no PS electric WP?
Anyone know if the champion ps and ac delete bracket will work with a electric water pump? I also have the smaller rjc crank pulley. Just thinking of ditching the p/s and switching to s10 manual.
Thanks Brandon.
IIRC the instructions mention something about a electric water pump...give Tom a call at Champion
yup it works. Local friends car runs it. What length belt i have no clue.
Adrian
I run that combo on my car. Mezziere H2o pump, no AC, No P/S. Very clean setup. Don't know the size of the belt, but it is tiny.
I considered doing it but couldn't imagine where to source a belt that short.
I don't run a t-stat, just a washer to slow flow. It's fine on the street stays around 160, but you have to let the car warm up to 160 first.
They make some small belts.
4 rib stuff is easy to find in really short belts. Lots of imports with short 4 rib stuff. 4 rib should have no problem driving only an alternator.
When I was looking into this stuff before, I saw it mentioned here about needing a special crank pulley from rjc to clear the electric water pump.
I have that pulley but don't think you will need it for this setup. I think you only need that to run the electric wp with ps. Which is how i have it now.
