Champion GN-1 Aluminum 14 Bolt Heads
Due to a tight budget, I'm putting most of my money into the block, and the aluminum heads. My thought is I can easily upgrade the rockers later. What do I need to run the stock rocker setup?
I'll sell my 1.65 scorpions with arp studs.
He has 8 bolt heads, Scorpions will not work. What cam are you running? You can use stock rockers on those. Otherwise, you need T&D rockers for 8 bolt GN1's that are close to $600.
I am going to get the Revolution X Roller Cam Kit Morel Lifter 210/215 set up from full throttle.
