Champion Heads,4.1 block w/ heads,cam,pan,3.8 crank,+ alot more, RJC girdle
5 LTR KLR
* Champion steel ported heads with bee hive springs and stock shafts. Heads were just pulled off running motor to put aluminum heads on now. Everything is fine.
$900
* 4.1 standard motor (number#: 291) with extras. Purchased from board member in summer and it was checked and has no cracks. Just never touched. Going different route. Has turbo 3.8 crank, front running cover, Precision 218-222 cam with lifters, stock 3.8 heads, oil pan, fly wheel, #2 & #3 billtet caps and the other stock caps, harmonic balancer,oil pick up tube, and some other hardware.
$550
* 14 bolt RJC girdle with all hardware plus stud bolts as well
$350
* J&E .030 light weight pistons mounted on stock rods - also include ARP rod bolts in like new condition
$400
Champion Irons...
Can you send more pix to: Smokin_SS@yahoo.com
Also...how old are the heads? Any additional porting other than what is done from Champion? Set up for FT or Roller?
Whats your best price?
Thanks!
Do you know who installed the center caps? What bore are the cylinders? Can you ship to 18346 PA for $550?
Sorry guys I haven't responded sooner!!!
EVERYTHING SOLD....all I have left are some AZ rust free doors and Aeromotive Eliminator fuel pump with regulator, bradied lines, fittings, fuel filter plus more
