Champion Heads and porting cost
vader87
Protected Freedom for 27 years! Thank a Veteran!
Just got an email breaking down the cost for GN1 heads and porting cost. Just wanted to pass it along!
Robert
The GN1 Heads complete are $1695.00
Full Port Labor on the Heads is $650.00
Hydr. Roller Spring Upgrade is about $62.00
Is the 224/224 Cam a solid roller or hydr. roller? If it a solid roller the spring upgrade will cost a little more.
Tom
Champion Racing Heads
Robert
Tom
I thought they already came set up for a hyd roller cam .
Yes I did too. I dont understand why it would cost more $$$$ for the heads to be setup if you are running hyd vs soilds or vice versa.
Different springs and/or locks & retainers probably.
K.
thought they were already ported cnced? how they flow compared to cast irons?
Yes, they do come set up for a hydraulic roller cam. The springs that come with them should be good for about 6,000 RPM's. It appears as though Tom was asking him if he had a solid or hydraulic roller cam.
Those heads should flow at .500 lift a shade over 250 @ 28” on the intake side and around 200 on the exhaust side. The numbers stay nearly the same @ .600 lift.
