slamming 6
Drag Master
- Jul 21, 2003
Whats the difference between there new intake and there ported stocker.TIA,AL.
SignUp Now!DCVING 6 said:Better picture when I get home.
Jeff Strube said:That looks like a Stage Motor tell use about it.
How much are the New Intakes Running for Price and How Complete are they
I am running one right now with oem fuel lines on my 109 block. Tom supplied the pressure side fitting for the stock line and the return side connected up to the regulator with little problem.norbs said:They are around 700 and they complete with upper plenum all bolts and fuel rails with fittings. You will have to supply your own feed and return lines the factory ones wont work.
