Feb 7, 2006 #1 D dirtbag New Member Joined Jan 13, 2006 Messages 41 just changed the pump with walbro 340 and hotwire kit, no pressure on first start up. checked wiring -ok. hit bottom of tank and the pump worked? worked for 2 days and happened again. any idea? thanks
Feb 8, 2006 #2 K Killa-Cotton New Member Joined Jan 30, 2006 Messages 77 Sounds like a short somewhere. I know you said you checked that but you may want to check it again. Other than that it may be a faulty pump.
Feb 8, 2006 #4 D dirtbag New Member Joined Jan 13, 2006 Messages 41 what are the chances of getting a bad pump?
Feb 9, 2006 #5 D DonnieShort Who's Next? Joined May 27, 2001 Messages 1,213 dirtbag said: what are the chances of getting a bad pump? Click to expand... It's hard to say, nothing is impossible but I would recheck everything in the wiring and relay set up for a start
Feb 9, 2006 #6 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 Make sure you got a good ground- you can add a ground strap from tank to chassis- should help. Also check the fuse.
