Changed MAF pipe. Car is hesitating. Help.
moyersgn
Just changed from a stock Maf pipe to a 3" aluminum pipe. Car is hesitating on take off. Here are scan numbers. Any help is appreciated.
O2 816
AF 05
L8 30
Bat 13.3
Int 128
BL. 142
Mph 00
Clt 191
R 900
Tps .42
Iac. 44
Cc. 193-204
Nal 00
Does the maf go to 255in the AF when you go wot?
When the car is idling, if you tap(not hit) on the maf with a screwdriver handle does the car stumble?
I'm guessing you are still running a stock maf.
Fuel pressure good?
What about the vacuum lines? Are they in decent shape and not leaking?
BLMs are high so ECM is adding fuel and it's running rich. Could be compensating for a vac leak or an O2 sensor is flaking out.
IAC is a little high too so more oxygen is being let by the throttle body blade and ECM is trying to adjust.
I'd try adjusting the IAC, bringing it closer to 20. Then you'll have to readjust the TPS too, setting again at .42.
Start there are see what that does for you.
