hi guys,
i decided to change my wires because 2 of the rear connections to the coil had rust and didn't click on the coil so i decided to buy some new msd 8.5 wires. I felt there was possibly a little rpm miss when driving and i was chasing down why the car was shootin black smoke.
well i changed them 1 by 1 so i wouldn't mess up firing order. I cleaned the coil contacts and used dilectric grease. reset the ecm by unplugging the orange wire near the battery.
now when it starts and runs awful. it will sputter and almost die. when i tap the throttle, it starts to miss. revving it is just way off too. it even backfired or knocked on me.
i have a power logger and all the idle numbers seem to be within spec from gnttype.org quick reference guide. In fact the g/s numbers for the maf was better after i swapped wires. before it was at 9+ and now it's at 7.
my set up is stock motor, heads, turbo. TT chip, lt1 maf, translator (dip switches set up,up,up, down and base set at 0), tps-tec (set .42 volts), k&n cone filter, caspers heated o2 harness and new o2 sensor. fuel pressure at 43psi w vac line off.
i changed my vac lines to silicone beforehand. car was running rich before i changed wires but it never ran so horrible. Rechecked the wires and all seem secure.
it's pretty frustrating when trying to fix something and it gets worse.
i did some searching and it seems stock maf were some issues. you guys think my coilpack just went south on me? seems just like bad luck
any help is appreciated.
