65skyturbo
- May 8, 2008
Well the saga continues, after finding that my original valve body was an early hydraulic valve lockup unit I went to the pick n pull and picked up a CR7 valve body in hopes to get my convertor to lock up. I have read that this is a decent VB to use and had high hopes. So I very briefly cleaned it and installed it with a KC sep plate that I had already modified. Took it for a test drive and now NO fourth gear. Figuring that maybe it needed its original CR sep. plate (only difference is the hole at 3 MTV according to the ATSG manual being in different location) I installed that plate and completely disassembled the VB and cleaned every bore, bushing and valve. Went for another test drive and have a very good 1-2 shift, slightly late 2-3 and only found fourth gear at over 75mph with letting off the gas. When I started to slow back down or got back into the throttle, even slightly, it would shift back into 3rd and not hold fourth. Please somebody give me some insight. This transmission had fourth gear fine with the other VB but lock up was not possible. Now with a better VB, I can't get fourth gear. The only things that have been apart since fourth gear was working is the VB, sep plate, and accumulator housing. Governor hasn't been touched so I don't think that is the issue. Any ideas?
