Changing door hinges or pins? Check out this door cradle I made
TR Custom Parts
Mark Hueffman - Owner
Had to change the worn out door hinge pins on my wife's 98 Jimmy this weekend. Not wanting to depend on someone else to help me out, I made up this door cradle so I could do it myself. Figured I would share so if you wanted to do your doors on a TR you can make one too.
What's needed. Floor jack, 2x6, two milk crates, pipe insulation, screws and fender washers.
I took the jack pad off my jack and replaced it with a transmission removal pad I had. Attached a 2x6 that I had laying around to the trans pad. Took the milk crates and cut them to fit the doors with a jigsaw. Screwed them to the 2x6 using fender washers. Put split pipe insulation on the cutout and a piece along the bottom of the door. Just jack up the cradle assembly under the door and go to it.
This worked out great as I have a bad back and now I could do the job myself without any effort and the door was not scratched or chipped from trying to fit it by hand.
BuickGn Boosted said:
............. This worked out great as I have a bad back and now I could do the job myself without any effort and the door was not scratched or chipped from trying to fit it by hand.
I know what you mean about the back thing. That is fantastic.
I use my motorcycle jack for all kinds of stuff.
All indentifying marks have been removed from the crates to protect the guilty. Patent pending on this device BTW. :biggrin:
And I thought I would make millions with this idea and would be able to get out of the Buick business. :biggrin: :biggrin: Price was right!
glad it worked out for you , stinks taking doors off with one person and if it slips it could get costly ,
the harbor freight one is cheap enough and you could loan it out on weekends for a small fee and quickly pay it self off ,
I like Mark's $3 solution - the stuff I have seen from harbor freight is junk and I don't need another tool taking up room in my garage.
