TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Had to change the worn out door hinge pins on my wife's 98 Jimmy this weekend. Not wanting to depend on someone else to help me out, I made up this door cradle so I could do it myself. Figured I would share so if you wanted to do your doors on a TR you can make one too.
What's needed. Floor jack, 2x6, two milk crates, pipe insulation, screws and fender washers.
I took the jack pad off my jack and replaced it with a transmission removal pad I had. Attached a 2x6 that I had laying around to the trans pad. Took the milk crates and cut them to fit the doors with a jigsaw. Screwed them to the 2x6 using fender washers. Put split pipe insulation on the cutout and a piece along the bottom of the door. Just jack up the cradle assembly under the door and go to it.
This worked out great as I have a bad back and now I could do the job myself without any effort and the door was not scratched or chipped from trying to fit it by hand.
