Changing From Lu To Nlu
SCOOBY DOO
BASED CANADIAN PATRIOT!!
FT sells a NLU valve...do I just have to change it? If so, what is the installation procedure. TIA.
Follow the instructions that come with it. Most dont require anything special and are an easy swap. You need to remove the check ball and o-ring from the input.
