Channel surfing at LS1
Chuck Leeper
Toxic old bastard
Staff member
I did it by weight and volume.
And you can really get after the cylinder pressure.🤙
Backpressure will be the enemy
Prepare to overspeed some turbos too.🤣
Everything gets amped up
The motor rpm wings up faster,
Converter flashes earlier and goes higher.
Boost curve is much more violent.
Car is on the tire earlier and harder.
With the new computers now it's easier to pick the target afr and as long as you have enough injector pump it will get after it.
Oh man Spool had to reply, now how many specifics can we yank out of him before he gets worried his street bets go down?
What % mixture you at or near, just speculation if you did do this on the street of course? LOL
You only 10% etc fueling increase too?
That part seems great if 40% mixture creates that big a jump on 2 degrees bump.
You really need to be able to pump it in, can't be light on the fuel system,
It needs to have a cushion.
Whats also needed is the ability to get it out On the exhaust side.
Backpressure is nobody's friend
