Hey guys I need some help I'm having a problem with my car not holding a charge ...I don't drive the car much it sits a lot... I know that's not good... I replaced the battery with a gel battery, and just replaced the alternator with one from kirban the 200amp one... So the other day I went to pull my ride out and noticed when I went for a lil spin the car wouldn't go over 35-40mph I noticed when I did the alternator I took off the intake pipe and maf well when I put it back on I didn't reconnect it after awhile I noticed it and reconnected it it was fine I drove it for an hour straight and on the way back home one of my Amps went off and the a/c was going up and down from hi to low I shut everything off and noticed the lights were starting to dim and after awhile the car shut off with no power after awhile the power came back on but the battery was low with not enough juice to start ... I towed it home jumped started it and it was fine I charged the battery over night and fired it up a couple of days later and it was fine I put it in drive and the lights were dimming again I went around the corner and the same thing no power over 30-40 mph turned it off and battery was low again and the volt light has been on as well.... Any info would help thanks in advance ...Rudy
