rickringle01
- Jul 12, 2007
I recently repaired a cracked header on the driver’s side of my 87 T-Type. After replacing the header, the alternator would not charge the battery. The car would start and run for about 5 minutes, once the battery was drained it would shut off. So I replaced the alternator, an AC Delco. I jumped the car off, the battery was charging according to the volt meter. I took it out for a drive with my son the other night, lost all electrical power and the car shut off. I jumped it off and it ran great. Since then I have run the car and it has not missed a beat. I put a volt meter on the battery and it's reading 13.5. Has anyone else dealt with this problem? Is it possible that the new alternator is bad? or is this a symptom of a greater problem?
