Similar problem to many, however, I didn't find a lot of different suspects when I read the search results.
The car isn't charging, it has a new battery and alternator. It started acting up just after I installed the Alky kit. I figured I screwed something up. I removed all power to the kit and lights. Still not charging. I checked the bulb for the VOLTS...it is good, but is not coming on. (switched it with a nearby one). Changed the 20amp with a known good one...nothing.
I checked the grounds by the battery...and rehooked them up again to different fender bolts (2 on 1 and 1 on the other). I didn't do anything to the harness that I know of.
Where should I be looking from here? Is there a place to search for power/resistance going down the brown wire w/o pulling every single wire out of the loom? Did I screw up at the grounds by the battery?
Suggestions? The cam sensor/crank sensor/engine strap issues just about burned me out and I got to drive it for a week. Now I'm back to a dead vehicle again...I'm still convinced it can be a reliable DD.
