dgreen1069
- Nov 19, 2004
What happens when a crank sensor malfunctions? What are the symptoms?
How much retard is normal at wot at the 1-2 shift on a stock car? What causes excessive retard on a stock car? I saw 10 on my scanmaster this afternoon while I was checking all my readings. That was at WOT just after the 1-2 shift. The O2s were around 810 (on pump gas).
I have a slight miss that is most noticeable at cruising speeds when the TC is locked. I have a scanmaster and everything seems to be where it should be. I have pulled my plugs and they look fine. I thought my injectors might be the problem, but now I don't know....I thought I would see something with the plugs. My car only has 6,000 miles and is bone stock. This problem is driving me nuts....it is like chasing a ghost. Would a bad coil pack cause a miss or slightly rough idle? Is there any way to find the problem without replacing parts one at a time? Anyone near No. Va that knows these cars? Please help before I go nuts!
