Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
This is about the cheapest method I've found to inject water/alcohol into our carbed turbo cars. It even saves a liitle gas according to the EPA. But the EPA doesn't like the emissions. The FTC report link I attached also confirms that it does work, (gas saving gadgets with one asterik), but the FTC adds that using this mod may be considered tampering. (LOL! All you guys with window washer sprayers have been doing this for some time).
In fact, this idea is better than a WW sprayer or that expensive pump from Northern Tools and the expensive nozzles. The key word is CHEAP!! No expensive parts to buy or fabricate and no electronics.
This really is a simple idea. Once boost kicks in the pressured airstream goes thru 28 and shoots into 22. The nozzle is a simple design just like a carb venturi/power valve. Once the pressured air passes thru the nozzle it creates a suction that pulls the fluid thru 26 that is attached to a fluid container. Both lines have a check valve.
The more boost, the more the pressure and the fine atomized mix sprays into the carb. The beauty of this is that spraying only happens when load requires it. It's all governed by the turbo. Plus, the atomized mix won't hurt the turbo impellers and the end result is cheap easy power!! Little, or no detonation.
Carbed turbo dudes looking into alchy or water injection should not overlook this idea. It's cheap, simple and do-able. I'm changing my plans with the big pump and gonna give this one a try.
http://www.ftc.gov/bcp/edu/pubs/consumer/autos/aut10.pdf
http://www.patentstorm.us/patents/pdfs/patent_id/4411224.html
