Cheapest place to get seat brace kit
Turbosix
Where is the cheapest place/vendor to get the rear seat brace kit?
Also how about the front frame braces?
Also the body to frame bushings?
And finally where has anyone found a cheaper place to get Bilstein shocks for the GN than the $205 at Shox.com?
Also how about the front frame braces? Thanks
The "cheapest place" I know of is your local you-pull-it yard.
For rear seat braces use underhood braces found on a full-size Cadillac from 1977-84. The pair of rods going from the spring tower to the core support work fine. You need to get these from 2 cars for a total of 4 rods. One end needs trimmed and a hole drilled at install.
Front frame braces are found on Olds and Pontiac intermediates. Not all have them, best bet is late 70's, early 80's.
$30 or so in the parts for sale section for the front braces. Painted up and work fine. Delivered too.
Rear braces can be made from real electrical conduit or perhaps EMT in 3/4" size. Not sure about the 1/2" strenth.
Or Kirban has them.
Those shock prices are decent actually good. :)
Kirbans crossbrace for the front is also a very good idea.
Thanks for the replies,
I know it would be best to go to a bone yard and get the braces, but, i don't have the time or the tools.
Do you know if one vendor sells the stuff cheaper than the rest?
205.00 is the best deal that I could find. I looked everywhere for these shocks. If there is a better deal on these it would be stealing.
