Check ball size
HellOnWheels
HellOnWheels
Seems I've read that one of the check balls that install in the vb is larger than the others, if so which one?
TIA
HOW
Some kits give you a
.265 check ball for the center valve body check ball location just in case the spacer plate is wore out,which if the spacer plate is the soft stocker it's a real good chance. Stock check ball size is .250
Mike.
