Chip ID ?, ECM
Charles Young
C Young
With this chip, does it really matter what turbo I have? I ask because I did not put turbo or chip in this car and I know the sheet that came with the chip lists a specific turbo but I'm not sure that is actually the turbo in the car. Thoughts?
Also, I have only had one of these cars before but I don't think the ecm had this ribbon cable coming from the bottom. What is it for??
Thanks ahead for any info!!!
That ribbon cable is likely for an older, no longer supported logging device called Direct Scan. Follow the ribbon and there's likely an interface box on the other end.
If you find the interface box, it's not a bad idea to get it and the ribbon cable out. It's about 99.9% sure that your laptop, if you have one will not support the parallel port cable on the other end of the DS interface box.
Powerlogger has made the DS obsolete. And as I said modern laptops don't even have a parallel printer port to connect to DS.
That chip will support a modestly wide range of turbo's. But it's an alky chip, and as such must be run with alky because of the HIGH timing and boost.
Ahh, yes I bet you are right. I got an old laptop that came with the car and a Direct Scan disk. Thanks!!
