Ok, so I have a turbotweak.com chip burnt to work with my 87 ECM and my stock 85 coil, mod, maf, etc. But, still having problems with my car(MODS:V2 intake/spearco FM/TA-49/40# inj.):
If I go half throttle get up to around 5 or 6 #'s of boost then the car just bucks or hesitates...no knock, but won't go anywhere either. But, if I floor it right away it goes right up to 10# of boost then slowly dies off to 6 or 7#'s. Then just hits a wall and builds no boost. Did notice if I take the air filter off that she pulls at 10#'s a little longer(thanks Broke1), but eventually does the same process. So, fuel is set to 38#'s line off anything above this and the above is even worse!! Eric said it should run at 43# with line off?
Another thing I just remember is that I never swaped over my calpak from my stock computer, is that causing probs?(trying to get ECM back from a board member that is borrowing it)
My other question is can I throw in a 87 chip made to run my 40# red stripe injectors(like a mass produced one) with my 85 maf, coil, & mod?? Would it run good enough to tell me if my chip is causing my bucking or hesitation problems?
I have a low boost problem and hesitation/bucking/shaking prob. I just want to get this hesitation one figured out first. I am going to look into my spark plugs(running autolite 24's gapped at .035) and wires(msd's) later this week. Coil/mod is a know good one too. Will try to get T-link on the $%#^$ thursday. Just looking for the chip advice was going to try to pick up a good used 87 chip for my injectors. Thanks much, Nick
