Take a car that has the parts to run low 9s and make a few passes at the track and average about 10.5 at 128mph with only 20 lbs of boost and shifting at 6k. You have a 60ft of 1.55. This is done with a stock ecm and maff using a chip. Now all you change is adding a DFI, Fast or ??. Using the DFI to tune tha car and then running at the track using the same launch, shift points and boost, and assuming same 60 ft what could you expect to improve on the ET and MPH if any ? IT is a Stage motored car. Thanks
