chip question
rwrows
i just bought an alky kit and i found a few used TT chips for my 60# injectors. my question is does it matter what turbo, converter, etc I have? or will a TT chip for 60# injectors work no matter what? thanks!!
Contact Eric via email and give him the numbers on the chips. Then, he may be able to tell you which one will be the closest to your combo.
Until then watch the scanmaster for low 02s and knock.
The turbo and boost you are running do matter. When I went from a TE-44 to a 6262 I was just about at max for adding fuel in the TT chip. I sent the chip in to Eric to be re-burned for the 6262 and the base setting so far has been perfect (only one time to the track since the re-burn).
