Hey Chris
I'm the guy in Canada that bought a sh-tload of 700R HD pieces and a 2800 convertor from you this time last year. Thanks. Works great. :biggrin: Question
.. on the speedo output my trans has a device that changes the entry angle of the speedo cable by 90* as this trans is in a jag and the tunnel is to close to screw the cable straight on. The square drive piece that slides into the plastic trans gear is broken
. What the hell do you call this thing (the 90* unit) so I can order another one. Without it I have no signal to the 'puter so no EGR (TPI motor) no canister purge and no high speed leanout, so I need to get a new one of these asap! Thanks for your time.
