Here goes
Classic Fast Box, B2B, Hall Effect Pickup
Fast Crank Decoder
Fast Edist
Cannot get spark. It will fire the coils when I first hit the key, and will fire them again when the key is released.
The Edist shows Green LED on, Red will blink one time when I try to start, Yellow will pluse when starting. Are Red and Yellow suppose to be on all the time? Dip switches set per Fast Instructions
Fast techine says it's low voltage at the Edist, but I got 11 volts there when cranking
It is wired per Fast Instructions. The injectors are firing.
Any ideas? or Tips?
Fast Crank Decoder
Fast Edist
Any ideas? or Tips?
