Speed_Dreamin'
- Sep 30, 2005
Any one have suggestions on how to best clean corroded wiring terminals?  Specifically, in the harness at the ECM and the ignition module?
SignUp Now!Heat shrink & seal butt connectors are much faster and easier than solder and heat shrink
Sent from my VS990 using Tapatalk
Well since they are THE approved method of repair for air bag circuits per GM and the fact that Ive used thousands of them over the years with zero issues I would strongly dissagree with that statement. Everything from air bag circuits, ECM & other module replacement connectors, medical equipment repairs, etc. Not 1 failure. Im not talking about regular butt connectors. I'm talking about properly sized butt connectos that heat shrink and contain a sealant to make a weatherproof connectionBut much less reliable.
	Once a terminal is corroded, you can't ever fix it. The tin plating on the terminal deteriorates, leaving the bare brass base metal, which tarnishes naturally. When brass contacts tin, it causes further corrosion via electrolysis, due to dissimilar metals.
There is only one fix; replace all terminals involved. And if the ECM connectors have terminals that are corroded, the ECM itself has taken a hit - you will be replacing that end as well.
Would it be better to just de-pin the connectors, cut off the terminals and crimp new terminals on and then push them back into the original connector? I don't see the terminals by themselves on Casper's website. Are they available? Would need the correct de-pin tool too.
Or is it preferred to just splice the pigtail connector?
