etriebe
- Dec 2, 2008
Stock block from 85 Grand national casting number 25524140 Bored .30, align honed, cam bearings and freeze plugs installed, 20 bolt pan. can be used in 86/87 but there is no hole drilled for turbo drain line. $300
Comp cams kit with cam lifters and timing set K67-246-4 $200
ARP Head studs for 85 block $85
Champion cnc iron heads brand new in box spring for non roller cam $1000
factory 86/87 lower intake manifold $90. SOLD
2 Upper plenums 1 with RJC power plate $75 or $95 with power plate POWER PLATE SOLD 2 stock uppers $75 each
RJC bullet proof head gasket set $100. SOLD
stock replacement motor mounts $15 each only have 2
