Cleaning oil cooler?
Jon01
Anyone got a good way to clean out an oil cooler? Just something that will get some of the metal that is no doubt in there after flattening a lobe.
Getting a new radiator is not an option at this point.
Thanks for any help,
Jon
Get a new one, bypass it or run an external cooler. Those are your only choices. It can't be cleaned.
For the price, don't clean it just get a new one. It may be possible to clean it, but price versus the damage done by a bit of metal is a no brainer.
I have a mechanic friend which had a pressuriseable can so I ran many cycles of solvent thru it in both directions then water pressure then air pressure in both directions also plugged the oil pump bypass, added a biggie oil filter and a TA performance booster plate.
