V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
See the pics.
Red Magnecore wires only 100 miles on them.
Turbo Bracket
IC brackets
ATR left & Right radiator pressurization pieces (at top)
IMPALA Alternator that someone took a metallic blue spray paint can to. Could be repainted and look nice. Works perfectly, I think 160amp? (I know its more amps then the GN one)
Brand new TCI? line lock
Cyberdyne Air/fuel gauge
Cyberdyne oil pressure sending unit NEW
Stock Starter w/bolts
Stock Rear End cover w/bolts
Air dam that goes under radiator (comes with hardware)
1 pair of jounce bars
AC Box Heat Shield
1 Aluminum Drum recently turned
front bumperettes need paint
Stock oil filler tube
Stock fuel hoses in good shape that connect tank sender to metal lines
A couple oxygen sensors with low miles.
MAF Bracket
Torque strap
Hood trim (piece that goes on the rear part of the hood). Could use paint.
Couple turbo plates/gaskets? Not sure what these are, they block off the wastegate hole or something?
Taking offers on everything. This stuff is merely sitting in my garage taking up space. Lowballers are welcome.:biggrin:
Turbo Bracket
IC brackets
AC Box Heat Shield
MAF Bracket
Torque strap
