Cleaning out the garage! Bunch of Odds & Ends
V6UnderPressure
The Artist FKA Scott4DMny
See the pics.
Red Magnecore wires only 100 miles on them.
Turbo Bracket
IC brackets
ATR left & Right radiator pressurization pieces (at top)
IMPALA Alternator that someone took a metallic blue spray paint can to. Could be repainted and look nice. Works perfectly, I think 160amp? (I know its more amps then the GN one)
Brand new TCI? line lock
Cyberdyne Air/fuel gauge
Cyberdyne oil pressure sending unit NEW
Stock Starter w/bolts
Stock Rear End cover w/bolts
Air dam that goes under radiator (comes with hardware)
1 pair of jounce bars
AC Box Heat Shield
1 Aluminum Drum recently turned
front bumperettes need paint
Stock oil filler tube
Stock fuel hoses in good shape that connect tank sender to metal lines
A couple oxygen sensors with low miles.
MAF Bracket
Torque strap
Hood trim (piece that goes on the rear part of the hood). Could use paint.
Couple turbo plates/gaskets? Not sure what these are, they block off the wastegate hole or something?
Taking offers on everything. This stuff is merely sitting in my garage taking up space. Lowballers are welcome.:biggrin:
bumperettes
bumperettes, any rust or damage on these? how much shipped to 43517? thanks,chris
How much for MAF bracket, AC heat shield shipped to 48089? Also will buy ATR radiator pressurisers depending on what they do.
guys just throw offers, nothing reasonable will be refused. Please keep in mind that while lowball offers are welcome, I need to be able to still pay for shipping.:biggrin:
bumperettes
is the rubber pieces tight against the metal or kind of lumpy? any rust?thanks,chris
The following parts are sold.
Turbo Bracket
IC brackets
Torque strap
The following are pending sale.
Line Lock
Magnecore wires
Hi Scott, I bought that super clean gas tank from you. I am interested in the Air dam that goes under radiator (comes with hardware),Hood trim (piece that goes on the rear part of the hood),Could use paint,IMPALA Alternator that someone took a metallic blue spray paint can to. Could be repainted and look nice. Works perfectly, I think 160amp? (I know its more amps then the GN one),Brand new TCI? line lock, & Red Magnecore wires only 100 miles on them. Could come out this weekend. $100 for all. LMK,Thanks,Cliff
guys, air dam is sold.
still have:
oxygen sensors
cyberdyne stuff
jounce bars
AC heat shield.
fuel hoses
alternator
maf bracket
pinion snubber
starter
rear end cover
