FastRegalWE2
Wish I had another Buick!
- Jan 10, 2004
driver side header is kinda crappy, pass side is still nice. It has an extra O2 bung welded in it for the EGT I was running. I also ground the original O2 bung flush on the inside of the header to improve flow. The ports are slightly ported, I opened them up a little bit with a dremel. I ground off the original x-over nuts and welded on new Grade 8 ones, after I had them coated. The coating is Jet Hot 2000 in gray and is good way past 1600*F. The x-over is an ATR which I had welded but has since been cut and has a new SS band clamp for the joint. The coating on the headers was $225. I will part with all 3 pieces for $100 shipped in the 48. Im not sure if anyone would even want to use the d/s but the x-over and p/s are still in very good condition.
Mark H 3" MAF pipe with rubber ends for LS1 MAF to 3" turbo inlet and 4" end where the IAT goes. It is powdercoated gray but has quite a few scratches and the alt bracket bolt was diggin in on one side. Looks nasty there but does not go all the way through. Has clamps to. $25 shipped 48
Dual wastegate solenoids w/Caspers y-cord on a bracket. 1 new solenoid 1 original, both work fine. They say these are $75 new now, $50 for the setup shipped 48 states
Almost new heated O2 kit wiring and sensor, from Jays GN....about 100 miles, I am adding alky so dont need this anymore.....$50 shipped 48 states
stock vacuum block 86/87 $15 shipped lower 48
seat belt actautors $15 shipped
rear lower control arm spcers that go inside the control arm to keep it from crushing...$10 shipped
