Turbo Loyd
- May 26, 2001
Keep getting a code 22 even with the TPS set at 0.42 any ideas ? Should the TPS be set lower on an Hot Air Car.
Also keep getting a code 32 EGR. The computer says the EGR is on at idle, though it really is not as the actuator is closed. If you pull it the car idles poorly. If this a leaky solenoid ?
