code 34 after razors kit?
ADJMART
Just installed razors kit.The car really woke up!!!
Only problem is it is sending a code 21 and 34 now.Did my mass air take a dump or is it a fueling issue from the kit?After a 1/2 hour drive and the car gets warm it really stumbles at idle.
.42 tps and 4.92 at wot.
I would lower your WOT to 4.5 volts. 4.9 is not needed. That will fix one of the codes.
The MAF code.. sounds like MAF is taking a dump. Unless you have some other gremlin like bad grounds on the back of the engine, computer connectors getting wet with water, chip issue, etc.
Non alky kit related.
thanks for the reply.Your kit is awesome by the way!Went together super easy and the performance difference is unbeliveable.Best value per dollar I ever spent.
