B
Broken down
Guest
I have had this code on for some time. I have replaced I think almost every thing that would cause this problem. I am thinking I may have fixed the problem.Then I may have made another one?
I have a WELLS coil pack and Module.I have taken the volt at the ECM. It's 5.7 volts ,so then I went to the Module Harness it came out of the module at 5.7 volts as well.So I don't have a volt drop. But My undering standing from the large Buick book .The ECM must read 6 volts.So with it being a little short it's going in to simultaneous mode.
So does it sound as I need to get the WELLS unit out and put in a A/C Delco unit? I guess it the module the give the 6 volts ?
And what is CKT 630?
Thanks,Rob
Thanks,Rob
