code 45
rb84gn
My car sets a code 45 only at idle.has sence I bought it any ideas why it would do this fp set to 40 line off 37 line on turbo set to 15#
Check your BLM's. My TTA does the same thing because the BLM's are around 108-110. If you goose the throttle it goes away. I am pretty sure mine is due to a vacuum leak, yours just may need IAC and TPS adjustment.
HTH
