Dec 27, 2010 #1 M mr.La Rue Member Joined Mar 30, 2010 Messages 53 Its finally running I put 200 miles or so hopeing 51 would go away but no luck. How to determine if it's the PROM OR COMPUTER
Dec 27, 2010 #2 K king kong Better,Stronger,n Faster Joined Jun 28, 2010 Messages 343 Did you try to take the chip out and clean contacts on chip and ecm. Reinstall and give it time to reboot? Don't forget to disconnect ecm power connector near battery or battery first.
Dec 29, 2010 #3 M mr.La Rue Member Joined Mar 30, 2010 Messages 53 code 51 I cleaned it up and checked the contact points and still no luck
Dec 29, 2010 #4 K king kong Better,Stronger,n Faster Joined Jun 28, 2010 Messages 343 change chip? any spars or friends with tr?
Dec 29, 2010 #5 M mr.La Rue Member Joined Mar 30, 2010 Messages 53 code 51 I do have a ecm from a 84 that I bought from a guy but its burnt . can a bad chip burn the ecm ? if not would I use bouth chips or just the prom
Dec 30, 2010 #6 Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Messages 9,641 mr.La Rue said: I do have a ecm from a 84 that I bought from a guy but its burnt . can a bad chip burn the ecm ? if not would I use bouth chips or just the prom Click to expand... If the ECM is burned, throw it in the trash. A bad chip can not burn an ECM. What "I" would do, is find someone local and swap ECM's.
