Code 42 is the C3I module or Bypass circuit failure.
Had nothing to do with the EST module on the fenderwell area.
The test involves checking the circuits 423 white wire Pin A on the module and circuit 424 the bypass pin B on the module tan/blk stripe wire.
They go between the ECM and the C3I module which is under the coil pack.
