coil spring
Hart007
How does everyone go about installing new Moog springs front and rear?
What do you used to get the load off the springs in order to replace them.....do you need to use a spring compressor & chain? Do the springs basically drop out of there perches?
I was thinking about putting new springs all around since the Moogs are not that expensive.
Just get a spring compressor. That’s what I did. Took about 4 hours to do it on the garage floor
I think this guy is a troll. He's made a bunch of posts on here.
One that's batshit crazy.
To aid in future searches.
For the rear, remove the lower shock bolts. When you lower the rear axle the springs will drop out.
For the front, it’s way easier with a spring compressor. I’ve run the spring compressor bolt through the frame to hold the spring in place while changing lower A-arms as well.
This guy is one of those email my friend about XXX part scammer.
