Coilpack Module Middle Bolt Size? One Through Wiring Connector
GNVYUS 1
TurboBuick.Com Supporter!
I'm in need of the size of that long skinny bolt that goes through the middle of the wiring connector for the module. It's probably an M6 x 40 but I'm not sure since it's missing.
OEM harness ?
Casper's reproduction harness ?
In either case it is supposed to be a captured bolt that is not to be removed from the plug.
OEM it is a 1/4 inch and Aftermarket is 7mm (close to same size).
OEM harness.
1/4 makes sense size wise as it's skinny.
Now the length part, 2"?
I remember it being long.
Pic of the bolt. let me know if you need more about it .
It might be for sale if the other guy wants to black plastic cover the bolt retains?
Thanks for the pic and the time. It looks like the actual bolt length is 30mm if you subtract the head length. Just got a SS bolt today so I'll report back on what works.
The bolt also is a 10-24 thread
Good look
I just got a 1/4 -20 × 1.5 long.
It's a metric bolt?
M5 x 30 maybe?
All solved for .75 cents at the local Ace Hardware store.
10-24 Stainless Steel screw at 1 1/4 long, easy in and done. Thanks
