- May 28, 2001
Finally, got a cold start log.
Seems the idle is rough, uneven, and shows some wild afr on the WB. [New PLX]
The engine is stock internals, new springs, turbo, 60# injs, TT chip to match, LS MAF/Translator, GM coil and module, Russ Merritt wires, AC plugs. All parts are new.
This is the first start since the engine has been reinstalled w/ the above changes.
Translator is set to original suggested settings.
Closed loop comes on at an indicated temp just over 100*.
Here's a log. NE 1 care to venture what may be wrong?
Note that fp is showing 56-60psi. It's actually 42/43, line off!
How do I use the adjust feature to get this corrected???
TIA,
TIA,
