RKHiPerformance
Turbocharged Sex Cylinder
- Feb 25, 2003
I posted about this same problem a while back and thought I had it resolved, but I was wrong.
Our 1986 T-Type is very difficult to start in cold weather. The car cranks easily, catches, and then stalls. After several attempts, I am able to keep the car running by working the throttle. The engine idles very roughly for several minutes, struggling and chugging, but as the engine temperature comes up the car will settle into a normal idle. When the car reaches normal operating temperature, the car runs and drives normally.
The Scanmaster (key on-engine off) displays coolant temp and ATS at about 40 degrees (which seems accurate), and both INT and BLM display 128.
I have replaced and adjusted the IAC, replaced the MAF, and replaced the way-rich Red Armstrong program with one from Eric at Turbo Tweak. None of these changes has affected the problem.
The car has 55 lb injectors.
The car starts easily in warmer weather. What should I look at next? The car has become basically unusable.
