coldstart afterstart help
jpwalt1987
I need some help with the cold start program on my gen 1 BS3. The car will start with no problem but once it fires it will run for a second then it will go dead lean and die. I have adjusted the coolant warmup fuel but I dont believe that is where the problem is. What table do I need to look at to make adjustments? Thanks, Jeremy
I went and took a good look at the program and increased the afterstart correction for the coldest temps. It was at 82 for the three coldest temp blocks so I just jumped it to 99 to see how well it it would do. Fired right up. I will dial it back from there to just enough fuel for good starting but not too rich. It is 31* here. Its not supposed to be this cold in the south!!! :biggrin:
What kind of AFR should I look for at start up at these cold temps?? Just rich enough to stay running?
