I had the trans rebuilt in Feb by a GM tech who was reffered to me as being very good at transmissions, but hadn't built a lot of 200's. I had him build it with Bruce's parts (10 vane pump, bigger boost valves, blue plates, billet servo, Alto Band, roller center support, etc.) and to his specs. But used my old orange stripe converter which had the clutch fall apart in several months later. So, I replaced the converter and changed the fluid in it several times hoping I would be alright. But, unfortunately there was so much junk in the fluid that it seized up the pump and broke some stuff.
So, this time, I am going to do everything right. Tim Capper at Detroit Trans. is tearing down the trans to look for any other broken parts and reassemble it and new 10 vane pump and 9/11 converter are on their way from Bruce. All is set for me to put it back in this weekend.
How about you? What are you having done? ETA? Are you going to try to make it to the Pueblo races?
