Maddening ignition problem. Ideas welcomed. Occasionally when turning the key to start the car it just clicks. Repeat a few times and it starts normal. I was sure it was a tired solenoid so replaced starter. Nope still occasionally clicks. Thought 6 yo battery might be done. New battery fully charged still occasionally clicks. Now I'm sure it's the ignition switch. Change ignition switch. Nope not that either. Then decided it must be the hidden kill switch. Changed that out. Still Occasionally clicks . what the hell am I missing here? Thinking maybe starter kill switch wire splices are 20 yo and might be loose or oxidized so that's next check but after that I'm stumped. I did try lowering the tilt and that might have helped but is there a wire in the tilt column I need to check?
wtf?
