I tried out the 108 + chip Sunday with limited success. I turned on the
boost assist. and the car was a dog out of the hole. I had better success
with it turned off.
I'm not blaming the chip. I must be doing something wrong. The car
takes off about 20' out and you can hear (and feel) the tires breaking
loose. then it pulls all the way to the end of the 1/4 mile. (107.77 MPH
was the best of the day) , but my best ET was only a 12.97 @ 22 # of boost ,running C16. Best 60 was a 1.8XX. Where with Jay's VT chip I once had a 1.77 60' , but the MPH if about the same for both chip's 107 to 108 , so the engine is making the same power.
What is the best way to stage using launch assist ? Should I just nail the
gas to the floor ? . I'm looking for suggestions. I need it to pickup in
that first 20 or so feet.
I also noticed the "below 10# fuel spool up" I did not adjust that. that
was left alone (default setting) . Should I lean that ?
On the plus side with the 93 chip and lean cruise I'm getting in the mid
twenties gas mileage wise.
I'm just looking for advise.
The car has a Stock D5 converter and a TE44 turbo 2.5" downpipe,gutted cat , 3" single shot exhaust , ported heads , 206 cam , cold air intake, No
exhaust leaks.
Any ideas on what I am doing wrong?
with it turned off.
exhaust leaks.
