Complete 87 Longblock-and I Mean Complete
tbirdv6
fresh rebuild 10K miles ago
This motor is complete less injectors & turbo!
Top to Bottom:
J Jackson Ported 62mm TB w/plenum(both are ceramic coated-chrome like), RJC Power Plate & Accufab Adj Fuel Press. Regulator
Ported Intake w/EGR removed
Ported Heads
TA Headers (Stainless) & Crossover
Billet center caps
JE pistons
All intact,all sensors,coil pack/ignition module,starter,flywheel, ALL ACCESSORIES (AC comp,Alt,WP...etc)
In other words still has the BELT intact
THIS is Literally a drop in, less injectors & turbo
Oil pressure was 25 psi hot
This was a tight running daily driver until I pulled it
ALL you need is your choice of injectors,install new motor mounts,plug all electrical connectors & turn the key on!!!
Looking for best offers over $2500
located in Tampa
Will ship via truck lines(freight collect)
FRED
turbobuick4@yahoo.com
Could you send me a number to reach you with...or give me a call...732-778-2273.I am interested in the motor.
Thank You,
Shawn
Fred...
Can you send me your number again...I cant find it.
Thanks,Shawn
Top to Bottom:
Ported Heads
Billet center caps
JE pistons
located in Tampa
FRED
Still available
FRED
