Complete Stage 2 On-Center motor Complete with turbo!
Otto J
selling my complete Stage 2 engine,It is fresh with 8 passes on it 153 on center block cross bolted front and rears
3.625 BMS Crank,Oliver Rods,Diamond pistons
RPE Spec Solid Roller,all brand new cam,timing setup,lifters,matched springs and pushrods.Danny Bee Cam retention setup.
Heads are Champion "R" heads just redone by RPE also,All new ARP Head studs,cometic head and intake gaskets
They have T&D Shaft mounted rockers(Not the cheap ones)Valve Covers are Champion RPE Racing Engines.
Intake is a BGC ported with RJC spacer 70mm Throttle body 160# injectors.Oil pan is a stock style made deep, baffled with external pickup and complete Duttweiler oil pump assembly with remote filter mount
BHJ Balancer,JW flexplate,Champion Non a/c bracket
Meziere electric water pump,HR Parts mounts
MSD Billet Distibutor with MSD Merritt black wires
Custom ATR 4 bolt headers,
Borg Warner S480 turbo
It is 100% assembled
Motor has gone 9.30s on radials with a safe tune at 26#s of boost
16,000 firm
Can be heard running,Will bring running car to BG you can see it run,And ill pull it out if you buy.
Awesome Rolling chassis to follow shortly.
engine for sale
Otto, any prospects on your engine yet? in august or sept, im going to try and sell my car with three complete stage 2 engines and one new off center bare block, and a lot of spare parts. good luck, see you in bowling green [ill be there with my wrinkled up old car]
No sir,So on that note i bid you good luck selling.
See you in BG pal.Ill be there running in out hoping for some 9 teens
I doubt it.I dont think Len plans on attending with the blue car this year
