Nov 17, 2003 #1 B buickboy Active Member Joined May 24, 2001 Messages 1,151 I run a T-70-1 and a HD Factory type actuator. Runs at WOT i can hear the turbo trying to surge back-like you let off the throttle after boosting it. Car flies and boost is rock steady to 24lbs. Any ideas. Mitch
Nov 17, 2003 #2 T The Radius Kid Active Member Joined Jan 26, 2002 Messages 2,596 Could be leakage in the I/C,piping to the T/body.Been there before[overtightened clamps on a V1 setup].
Nov 17, 2003 #3 B buickboy Active Member Joined May 24, 2001 Messages 1,151 Thanks, I will check the connections.
