turbo buicks
ESADAH!!!
- Jun 13, 2002
guys i have a question about comp surge under light throttle, hi load (IIRC) such as passing a car on the highway. how many of u have experienced this with a large turbo, specifically a BB72Q? i have been plotting out the specs for a stroked 231 (242 cid) on a comp map prog and im coming up good at WOT but at the initial full boost point and lite throttle, hi load (passing scenario) im running into surge. does this happen to you guys and if so what do u do about it? i was thinking about the highway scenario u could use something that would open the WG all the time, no boost, no surge, im not too worried about the initial max boost point b/c its right on the surge line and would only be for a second (maybe if any). i picked this turbo for its capabilities and features and the point im gonna be running it at is right at the most efficient point on the map, plus i got a deal on it. i would also like details on your combos as to what they are (in general) and where you make full boost and how much u wind it out. also i am using around 80-88% for engine VE in my calcs (ported big valve stk heads w/rolr cam) and 80% for PSIC eff. and 78% for the 72's eff. per the rating on the map. and as a side question, would revving to 6500 be unsafe for a girdled 109 with forged stroked rotating assembly and what about a non rolr cam, is this in the valve float range?
thank you for reading
